-   -   Non-Destructiv Injector Shroud Removal? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/332677-non-destructiv-injector-shroud-removal.html)
euro911sc 02-26-2007 08:34 PM
How can I remove these from the intake pipes without destroying them?? I need to clean these... obviously ;)
Bottom Side:
http://forums.pelicanparts.com/uploa...1172550768.jpg
Top Side:
http://forums.pelicanparts.com/uploa...1172550838.jpg
Best regards,
Michael
Henry Schmidt 02-26-2007 08:42 PM
Tap them out with a valve guide stepped punch.
They are available and inexpensive if you happen to break one.
SP2 02-27-2007 06:43 AM
There is an o-ring that goes around the outside of the sleeve in addition to the one inside the sleeve (or around the FI). Might want to replace both of them
euro911sc 02-27-2007 09:52 AM
Seems easy enough. I pushed on a couple of them and they didn't budge so I figured I'd ask. I don't have a valve guide drift, can I make one out of a wood dowel? or threaded rod and washers?
Also, it looks like I was getting a lot of blow back through the exhaust valves... would this be normal conditions for an intake pipe ('82 ROW SC w/~90k miles)??
Best regards,
Michael
