Less brakes, more gas!
euro911sc's Avatar
Non-Destructiv Injector Shroud Removal?
How can I remove these from the intake pipes without destroying them?? I need to clean these... obviously
Bottom Side:
Top Side:
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-26-2007, 08:34 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Tap them out with a valve guide stepped punch.
They are available and inexpensive if you happen to break one.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-26-2007, 08:42 PM
SP2 SP2 is offline
SP2's Avatar
There is an o-ring that goes around the outside of the sleeve in addition to the one inside the sleeve (or around the FI). Might want to replace both of them
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 02-27-2007, 06:43 AM
euro911sc's Avatar
Seems easy enough. I pushed on a couple of them and they didn't budge so I figured I'd ask. I don't have a valve guide drift, can I make one out of a wood dowel? or threaded rod and washers?
Also, it looks like I was getting a lot of blow back through the exhaust valves... would this be normal conditions for an intake pipe ('82 ROW SC w/~90k miles)??
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 02-27-2007, 09:52 AM
