84toy's Avatar
Valve spring specs needed
I'm working on a 95 3.6. Does anyone have the valve spring specs so that I can check them?
I have a valve spring measuring scale but I could not find any specs in the service manual. Any help appreciated....
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 12-20-2007, 11:28 AM
abit off center
cgarr's Avatar
I would be very interested too, I installed the http://www.drcamshafts.com/ springs and he lists a nice table for his spring rates per inch. But that does not help you..
______________________
Craig
G2Performance
Old 12-20-2007, 11:34 AM
84toy's Avatar
Perhaps if someone has a new spring that they can check and post the results....
Paul S
Old 12-20-2007, 11:59 AM
BURN-BROS's Avatar
They should be around 55 to 65 at the installed height depending on application. Measure them all, they should be within 5% or so from one another.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 12-23-2007, 07:28 AM
84toy's Avatar
Thanks, they are all within 2 pounds of each other. I have 70 lbs on the exhaust and 63 on the intake. (intake and exhaust have different assembled height specs)
Paul S
Old 12-23-2007, 06:57 PM
BURN-BROS's Avatar
That looks good. Judging by the spring rates, I am assuming thats due to the hydraulic rockers?
Burnham Performance
Old 12-23-2007, 07:39 PM
