Less brakes, more gas!
euro911sc's Avatar
Which Stud Replacement for chain covers
My engine had a large y shaped arm on the drivers side chain cover. Nothing was attached to it. This is a Euro car. Would this have been the air pump or an air pump put on when the car was federalized?
Anyway, I want the arm go as it just gets in the way and is ugly. From PET the studs are 8mm x 60. The standard cover studs are 6mm x 22. I do not see an alternate stud like a 8mm x 22. Closest I see in PET is 8mm x 35 (999.062.010.02)
Can I simply buy a generic 8x22 and stick it in there or should I go with the 8x35?
What do I use to plug the hole left by the stud indicated by the green line?
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-09-2007, 12:06 PM
jase007's Avatar
Yes.
I had this situation on my '76 and the best solution is to remove the nuts on the studs holding the pump support bracket to the cover and put a caliper gauge on there to see if it is an 8 or a 6. [or just check the nut / stud]. If it is a 6 ... order similar lengths of 22mm as the other chain box studs [eyeball the boss on the cover to make sure it is the same thickness as where the other 6 mm studs poke through]. If it is an 8 then you need to source the 8 X 22. Perhaps McMastercarr.com if PP doesn't have.
My temp solution ... I slipped some nuts and washers over the exposed stud [after removing bracket] and torqued to spec. Not pretty but low $, it works and was a temp solution that I still have to get back to ... a year + later
*Keep the air pump, bracket, air injectors, air injector rail, etc... if your state requires these be in place when transfering title / new inspection... should you sell.
Jason
'58 -'76 P-cars
SSPI ~ JScott Racing
Old 03-09-2007, 01:27 PM
euro911sc's Avatar
Thanks Jason! No rules here in FL
They are 8mm for sure. I expect I can find a suitable 8x22ish stud in the PET and then order it. if not, I'll check my local metric supply place and then I guess McM. or MSC for suitable HW.
Still,what sis you do with the middle on that seems to be in the center of the cover?
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 03-09-2007, 01:37 PM
