Less brakes, more gas!
Which Stud Replacement for chain covers
My engine had a large y shaped arm on the drivers side chain cover. Nothing was attached to it. This is a Euro car. Would this have been the air pump or an air pump put on when the car was federalized?
Anyway, I want the arm go as it just gets in the way and is ugly. From PET the studs are 8mm x 60. The standard cover studs are 6mm x 22. I do not see an alternate stud like a 8mm x 22. Closest I see in PET is 8mm x 35 (999.062.010.02) Can I simply buy a generic 8x22 and stick it in there or should I go with the 8x35? ![]() What do I use to plug the hole left by the stud indicated by the green line? Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
I had this situation on my '76 and the best solution is to remove the nuts on the studs holding the pump support bracket to the cover and put a caliper gauge on there to see if it is an 8 or a 6. [or just check the nut / stud]. If it is a 6 ... order similar lengths of 22mm as the other chain box studs [eyeball the boss on the cover to make sure it is the same thickness as where the other 6 mm studs poke through]. If it is an 8 then you need to source the 8 X 22. Perhaps McMastercarr.com if PP doesn't have. My temp solution ... I slipped some nuts and washers over the exposed stud [after removing bracket] and torqued to spec. Not pretty but low $, it works and was a temp solution that I still have to get back to ... a year + later *Keep the air pump, bracket, air injectors, air injector rail, etc... if your state requires these be in place when transfering title / new inspection... should you sell. Last edited by jase007; 03-09-2007 at 01:44 PM.. |
Thanks Jason! No rules here in FL
They are 8mm for sure. I expect I can find a suitable 8x22ish stud in the PET and then order it. if not, I'll check my local metric supply place and then I guess McM. or MSC for suitable HW. Still,what sis you do with the middle on that seems to be in the center of the cover? Best regards, Michael
