Whats with all these #'s on my 2.7??
Here you see 9011051111R and then under the motor there is 911-101-101-7R
911-101-102-7R I though it was a 74 2.7 but I dont know what these mean. Also This was a great running motor, just looked dirty. What could I check for (Headbolts) before I reassemble?? Is this a better than stock clutch?? Thanks http://forums.pelicanparts.com/uploa...1173755067.jpg http://forums.pelicanparts.com/uploa...1173755135.jpg http://forums.pelicanparts.com/uploa...1173755207.jpg http://forums.pelicanparts.com/uploa...1173755272.jpg |
Those are all casting #'s for the various pieces of the engine.
Look for 2 numbers in the highlighted area below: - There should be the engine number stamped into the vertical fan support - The engine type is stamped on the horizonal surface near the oil pressure switch Post those two numbers and it will be easy to decipher. Regards, Andrew M http://forums.pelicanparts.com/uploa...1173789215.jpg |
These #'s show 1976 49State US 2.7 engine - hope that helps.
AM |
| All times are GMT -8. The time now is 10:10 AM. |
