How much $ do you have in your rebuild?
I am adding up all of my engine rebuild receipts and cannot believe how much money I have thrown on this rebuild. I have tried to save wherever I could and I do the work myself. My total is north of $8K to rebuild a 78 SC engine into 3.2. This amount includes M&K muffler and SSIs and staying with the CIS system. Anyone else want to share their secret?
Old 03-24-2007, 10:29 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Do not feel bad, way too much here. I am even selling stuff that I love to pay for future improvements. Custom mountain bikes and road bikes, my 72 911t roller, other odd and ends. All in the endeavor to make an out of date air cooled motor more powerful. At the end of the day I probably could have purchased a gt3 motor and put it in the car and called it a day. Wish I had thought of that before.
74 911s neverending story. two feet and a jetta for now.
Old 03-25-2007, 02:35 AM
304065's Avatar
That will teach you not to add up your receipts.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-25-2007, 05:01 AM
Less brakes, more gas!
euro911sc's Avatar
All my receipts are kept in a secret tin in the garage marked 'Broken Parts Bin'... *laugh* I don't dare add those up... If she who holds the purse strings found out I'd be installing hard wood floors and other honey-dos instead of working on my car for a year...
I think i might have about 3-4k into it as an stock rebuild... but, I've been part collecting for a year.
best regards,
michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-25-2007, 07:24 AM
E-85 sippin drunk
turbobrat930's Avatar
Re: How much $ do you have in your rebuild?
Originally posted by Michel J
[B\. My total is north of $8K [/B]
I have more than doubled what you have spent.... I know, it is sickening when you go back and think about it........and A friend and I did all the work ourselves
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-25-2007, 08:21 AM
Scott R's Avatar
7k in the engine...so far now add an extra $2300 for the transmission that was diagnosed last week. Whenever my wife needs anything done around the house, or the dishes done, she just brings up the rebuild.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-25-2007, 08:53 AM
fancytown
3.2 L top-end including new exhaust valves, valve guids/seals/keepers, 964 cam regrind, new rocker shafts, re-bushing rocker arms, and complete engine re-seal: $2200 in parts/labor. That includes a few while you're in theres like ref/speed/cyl head temp sensors. Plus $850 for a trans rebuild. So, just a hair over $3K for everything.
I did everything but the machining. This is my 2nd 911 rebuild, so I learned how to save this time.
all cars sold.
Old 03-25-2007, 08:59 AM
(the shotguns)
berettafan's Avatar
Jay can you offer some tips on what you did differently vs. your first rebuild to save money?
Old 03-25-2007, 09:42 AM
My totals are similar to Jay's. I have my '82SC engine apart and waiting for my heads and cams to come back. I have done everything myself except the machining. Reconditioning the heads, regrinding the cams (964) and reconditioning the rockers will come in at ~$1000. Consumables for the rebuild (i.e. bearings, gaskets, head studs...) will be ~$1000. I picked up a set of engine tin (mine was pretty rusted) for $100, a muffler for $50, crossover pipe $30. About $125 in parts to rebuild the CIS.
All in all, I imagine I will be somewhere around $3K. I don't think I cut any corners, but I kept things pretty much stock.
Geoff
'82 911SC (Complete rebuild)
Click here to go to the project website that chronicles the rebuild process
Old 03-25-2007, 10:13 AM
Scott R's Avatar
I guess my shopping list is the biggest so far then:
Motor:
New P&C's from EBS JE 10:5:1
New bearings
New CAM tower on the passenger side
New spray bars
Complete powder coat of all tin, fan, anything else attached to the engine for that matter
Crank work
Rod work
New to me SSI's
new stainless muffler
Oil lines
Timing chains
reconditioned rockers
964 cam regrind (thanks Camgrinder!)
Final assembly labor (I travel just about every week, so I can't get it done)
Transaxel:
New sliders dogs and syncros on 1 and 3 and 4
New shift forks
New shift guides
New bearings in case
Professional labor
I'll do the final assembley including installing the covers, shroud and injection. I'll also mate the transmission and install the motor.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-25-2007, 10:21 AM
Stranger on the Internet
patkeefe's Avatar
I have three rebuilds going on at the moment: 3.0 turbo project, 2.7 race engine, and 2.2. If I start adding, I will have to slit my wrists.
Pat
Patrick E. Keefe
78 SC
Old 03-25-2007, 04:55 PM
andrew15's Avatar
I stopped counting after NOS Mahle 92mm P&Cs
AM
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 03-25-2007, 05:35 PM
user & abuser
i've done a stock rebuild/re-seal and ring on a 2.7
taken that out to 95mm P&C's so it was a 3L, flowed the head and added SSI's..
sold that
100mm Mahle P&C's
3.3L turbo case and oil pump
machine shop work
cariallo rods
raceware rod bolts &studs
ported heads (3.2L base)
Electromotive crank fire ignition
dual pluggs, 6 coils
front mount oil cooler
mod s cams
46mm webers
B&B headers, sold them, European racing headers.
ceramic coating
M&K muffler
powder coating this that and the other thing
+ labour....= 5 digit ouch....
edit you'll also see i have sold off and am selling many of my spare parts.... this isn't because i don't like them
vini vidi vici
Old 03-25-2007, 06:00 PM
patkeefe's Avatar
Andrew
Since I did stop counting, I may need the Zenith kits after tax day. PM me if they don't sell on Ebay!
Pat
Patrick E. Keefe
78 SC
Old 03-25-2007, 06:15 PM
Interesting thread,
I don't add up my receipts but I do hide them from the wife...just kidding. You really got to love these cars because it's difficult getting your money back if you sell. For me, selling is not the objective...I love these cars! If your curious, I have a 3.2L Euro in a 76 Targa. I'm almost finished with this 2.5 year long project. I rebuilt and replaced just about everything, most of the work is done by me to save money. I even learned how to powder coat. At this point I'm about $5000.00 invested.
Regards,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 03-25-2007, 10:34 PM
Mine has a more traditional look. I would like to try doing a little extra powder coating with the next one.
Cheers,
Michel
Old 03-26-2007, 09:11 AM
911SCfanatic's Avatar
Once I broke $10k I stopped counting. I suspect it will end up somewhere around $13-15k.
Bill G.
'68 911 Ossi Blue coupe
Old 03-26-2007, 09:29 AM
Gon fix it with me hammer
svandamme's Avatar
targa went up to 13-14K ish... euro's...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 03-26-2007, 11:29 AM
svandamme's Avatar
you powdercoated those heads?!??
Stijn Vandamme
Old 03-26-2007, 11:30 AM
euro911sc's Avatar
Reading this thread it looks like those that go with different P/Cs than they had spent much much more. To be expected, but the amounts are beyond just the parts...
if you are going to go... go big
-m
Michael
'13 Cayenne GTS
Old 03-26-2007, 11:35 AM
