The heads are not powder coated, I should have mentioned it before posting the pictures. The black treatment is a heat dissipating thin layer of paint to help keep the heads cool. I used various treatments in areas like my piston domes (ceramic coated), dry lube on piston skirts, oil release below pistons, dry lube on wrist pins and I also treated my valve surfaces with ceramic and stems with dry lube film.
Regards,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 03-26-2007, 12:26 PM
Gon fix it with me hammer
svandamme's Avatar
thx for the clarification , never seen that..
Stijn Vandamme
BIMDIESELBMW116D2019
Old 03-26-2007, 12:38 PM
A930Rocket's Avatar
About $14,000. I did all the work tearing it down and rebuilding it. This includes a new turbo, P&C's, new 964 cams, machine work, and some powder coating. All the shipping and small stuff adds up too.
Old 03-27-2007, 05:17 PM
boba's Avatar
After you buy a set of these everything else is pocket change (because that is all you have left).
Old 03-27-2007, 06:35 PM
This thread is making me feel better :-) Hope my engine runs.
Michel
1976 911S targa
Old 03-27-2007, 08:38 PM
Jeff Alton's Avatar
You guys can do the math...
3.4
10.5:1
Twin plug
DC44 cams (108 lobe centers on new billets)
12 new valves
new rocker arms
Race springs
Ti retainers
48mm Jenvey throttles
Microtech ecu and digital dash
ARP rod bolt
ARP head studs
Boat tailed case
Balanced
B&B headers
M&K GT3 Style muffler
MSD coils
Elephant front mount cooler (Setrab)
Bobs throttles take the cake though.... you should ask him about the rest of the car!! :0
Cheers
www.turn3autosport.com
Old 03-27-2007, 09:41 PM
Crusty Conservative
silverc4s's Avatar
When I bought my 70 S Coupe in 1989, the engine was running (well) but had low oil pressure, about 20 psi max, dropping to almost 0 at idle. It was all original with about 115,000 miles at that time.
It was driven for only about one month, then parked in my garage until mid-1995 when I started the rebuild.
All of the MFI was rebuilt by Norbert Eberhart & Gus Pfister
Added new SSI exhaust
Replaced one head and one cam tower
resurfaced 2 cams
New mahle 2,2 S P/Cs
New valves, springs, rockers, shafts, and assoc hardware
New Int. shaft, cam chains, sprockets, ramps, etc
New Carrera tensioners
New flywheel
New Alternator
Bearings & gaskets - all, of course
Machine work on cases for piston squirters, oil relief update
Machine heads
New oil pump
new oil cooler on engine
new oil thermostat, engine
New ignition parts, all except Dist body & Bosch CD
Powder coat air cleaner, all engine tin, rear engine mount plate
So there is virtually nothing old in my engine except the crank, rods, and cases now.
Total cost in 1999 dollars was pretty close to 20 big ones.
It does run like a dream & the original MFI purrs like a kitten. I am happy, but I would hate to have to do the same today...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 03-28-2007, 08:33 AM
A930Rocket's Avatar
Should have posted a pic of the final product.
Old 03-28-2007, 05:46 PM
