911 Rebuild Tools
OK Guys - I finished rebuilding my 83' 911 3.0 CIS & everything turned out better than I ever expected so here are the tools I don't ever expect to use again.
All of these tools appear as new and were used only once!!!! Head stud allen head nut removal tool 10mm - 30.00 Heat exchanger allen head nut removal tool - 21.00 Starter allen head bolt removal tool - 5.00 Flywheel bolt removal tool - 31.00 Transmition drain plug tool 17mm - 6.00 Cam Bar - 69.00 Clutch alignment tool - 6.00 Flywheel lock - 13.00 Engine stand adapter (converts standard engine stands for use on porsche/VW type engines) - 129.00 I am also including a couple of "homemade tools" that make the job easier. Total for all $ 300.00 you pay the freight. (save $45.00) I don't really want to separate. http://forums.pelicanparts.com/uploa...1173908797.jpg |
Bump
| All times are GMT -8. The time now is 10:58 PM. |
