911 Rebuild Tools
OK Guys - I finished rebuilding my 83' 911 3.0 CIS & everything turned out better than I ever expected so here are the tools I don't ever expect to use again.
All of these tools appear as new and were used only once!!!!
Head stud allen head nut removal tool 10mm - 30.00
Heat exchanger allen head nut removal tool - 21.00
Starter allen head bolt removal tool - 5.00
Flywheel bolt removal tool - 31.00
Transmition drain plug tool 17mm - 6.00
Cam Bar - 69.00
Clutch alignment tool - 6.00
Flywheel lock - 13.00
Engine stand adapter (converts standard engine stands for use on porsche/VW type engines) - 129.00
I am also including a couple of "homemade tools" that make the job easier.
Total for all $ 300.00 you pay the freight. (save $45.00) I don't really want to separate.
Old 03-14-2007, 02:47 PM
Bump
Old 03-28-2007, 07:39 PM
