Cam Lobe Pitting?
Hi, this picture shows a cam lobe that is pitted.
1 - Would you consider using this cam.No signs of wear + Rocker is OK.
2 - Has this cam been Re-profiled and the surface is starting to break up.
Anyone had a similar problem? Thanks in advance Chris.
Old 03-18-2007, 01:01 PM
fancytown
See here:
(go to bottom of post)
Rocker Arms and Shafts- Wear Condition
and here:
http://gruppeb.org/forum/viewtopic.php?t=4300&postdays=0&postorder=asc&start=45
all cars sold.
Old 03-18-2007, 07:54 PM
SP2 SP2 is offline
SP2's Avatar
I had a similar pitting problem. I asked camgrinder to look at the photo I posted and he said it would only get worse. I had mine reground.
On the other hand, JW told me he sees this alot when he does valve adjustments and can see inside, and he doesn't necessarily recommend regrind.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 03-19-2007, 01:18 AM
If I discovered this on a valve adjustment I'd leave it alone. Since you have the engine apart I'd fix it. You can have the cams refinished and the rockers refinished as well. It's not that expensive and you already have the engine apart.
-Andy
Old 03-19-2007, 10:06 AM
Smile Re Cam lobe Pitting
Thanks to all for their responce to my question. Chris.
Old 03-21-2007, 12:11 PM
