-   -   Cam Timing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/336439-cam-timing.html)
TimT 03-18-2007 08:23 PM
Cam Timing
Since cam timing is a topic that seems to throw doubts into engine rebuilds..
We recently took a Supercup engine, and twin turboed it
Only 4 cams to time :p
Initial set up
http://forums.pelicanparts.com/uploa...1174274206.jpg
Fixture and dial indicators in place
http://forums.pelicanparts.com/uploa...1174274291.jpg
Yeap degree wheel
http://forums.pelicanparts.com/uploa...1174274445.jpg
fine adjustments
http://forums.pelicanparts.com/uploa...1174274508.jpg
Cam timing
http://forums.pelicanparts.com/uploa...1174274566.jpg
FYI
TimT 03-18-2007 08:26 PM
Wonder why that one pic would not post... so here it goes again...
fixture with dial indicators in place
http://forums.pelicanparts.com/uploa...1174274770.jpg
TimT 03-18-2007 08:29 PM
ok I guess somewhere there is something funky in the filename... so I renamed it
http://forums.pelicanparts.com/uploa...1174274939.jpg
cstreit 03-19-2007 06:09 AM
Nifty tools Tim. You guys make them?
Walt Fricke 03-19-2007 02:20 PM
Thanks for a view of how the other 1% lives! That's some engine.
The latest Excellence notes that the 8 cylinder type 771 engine (used in the 907) took the factory 220 hours to assemble.
How long for one of these?
Walt Fricke
304065 03-19-2007 02:29 PM
I read that too, Walt, about the 771. The same paragraph said it took 16 hours to assemble a 906 engine, which is basically a 901. . . then again that's assembly only, not teardown, rework and reassembly.
Back to Tim's topic, what makes this engine's cam timing different than any other four-cam 996 motor? Not to downplay the significance in the slightest, on the contrary, those four-valve water-cooled engines are pretty complicated. Is that Richie in the photo?
