911SCfanatic's Avatar
valve stem seal removal
I can't seem to get the valve stem seals off of the guides very easily. The seals have a metal base that fits over the end of the guide. What's the technique for removing these? I can't really get a flat head screw driver on either end to use as a lever to pry the seal of the guide...also don't want to bugger up the cam housing sealing surface. These are '74 heads with possibly original seals. Thanks.
Bill G.
'68 911 Ossi Blue coupe
Old 03-16-2007, 02:54 PM
They should pry off with a screwdriver pretty easily......use a piece of leather or whatever to protect what you're prying against.
Aaron Hatz
Flat Six, inc.
Follow us on Facebook
https://www.facebook.com/flatsixinc
Old 03-17-2007, 08:22 PM
the two screwdriver method works pretty well. be sure the top screwdriver blade is on the dull side, so it doesn't gall the valve stem. the lower one provides a raised pivot point and protects the head from pry marks.
206 637 4071
Old 03-20-2007, 08:58 AM
3.4 Bigger is better
88-diamondblue's Avatar
Is there a way to remove them while the cam towers are on the heads and what tool would you use? Don't think a screw driver will get enough of an angle with the cam towers on.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 03-20-2007, 10:00 AM
stevepaa's Avatar
Maybe if you bend the tips of al ong long nose plier?
steve
old rocket inguneer
Old 03-20-2007, 10:21 AM
get a vw rabbit stem seal remover tool. basically pliers with cups on the ends.
206 637 4071
Old 03-20-2007, 10:47 AM
John,
I figured there had to be a tool for it. Thanks for talking the time to answer.
Michael
2020 Honda Passport
Old 03-20-2007, 11:10 PM
the rabbit seals are a bit smaller than 911 seals but the tool will probably work.
206 637 4071
Old 03-21-2007, 08:11 AM
