Stuck Wrist pins
Yesterday I was tearing down my engine, and in the past the wrist pins have always been a little sticky.
This time, they are really sticky.
I haven't tried heat yet, but wanted to know "how much heat???" should I try???
I also ran a threaded rod through the wrist pin and tried pulling the pins out (different ones that I could get to) by tightening the opposite end, pulling the wrist pin. Still no luck....
SO - How much heat???
Brian
Brian Keith Smith
Old 03-25-2007, 07:15 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Brian,
Mine were a bit sticky. I applied ALOT of lubrication, heat from a propane torch, and gently tapped them out with a wood dowel and large hammer. They popped right out.
I don't know what temperature they got too, but remember they get a good dose of standard operating temperature from the combustion chamber.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 03-25-2007, 08:15 AM
Oh yeah, I can't imagine I'm gonna heat them up nearly that much!
(remember mine's a turbo - smokin hot)
Thanks, just got back from the shop, where I tried heat, didn't work... Going back to hardware store to try to make a different puller....
Brian Keith Smith
Old 03-25-2007, 08:17 AM
JOT MON ABBR OTH
Try the tapping method with a wood dowel. You are less likely to break something/scar something. Do you have a dead blow hammer? They are cheap at harbour freight...
Remember to brace everything.
Once you get them out, take some emory paper (400 or no heavier than 220 if I remember correctly) and polish the openings and the wrist pins. It will make a difference!
Once they are out, check your openings to ensure they are not pulled out of round.
Old 03-25-2007, 08:32 AM
