Rickw96's Avatar
Unhappy Did a bonehead mistake
I hope this is not a bad one. I had to take out the small pin/screw that is in the flywheel that triggers the sensor for the crank position. It's the one on the outer edge of the flywheel. It sticks up about 1/4". I went to screw it back in and it snapped. I could not get the threaded part out so I stuck the head back in with some JB weld. I mounded it up on all sides. What do you think will it hold and will it trigger? I'm not to sure on how to test it.
Rick
Old 03-29-2007, 11:34 AM
It might hold. It's up to you to decide if it's worth the risk. How good are you at removing the engine? A set of reverse drills would help get the broken part out or make room for an easyout.
-Andy
Old 03-29-2007, 04:10 PM
Rickw96's Avatar
I'm not to worried about it holding. If it does let go I can drop the engine (took about three hour last time). I am more worried that I placed the JB weld all around and almost to the top of the pin, will it still trigger the sensor?
Rick
Old 03-29-2007, 05:37 PM
Talking
7000 rpms. I can't see it holding, but that's just a guess.
If it were me, I'd try it, but then it would back out and ruin the sensor and I'd be replacing two things, not one.
Old 03-29-2007, 05:40 PM
fix it properly now.
206 637 4071
Old 03-29-2007, 08:05 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Fix it right, get the pin out and install a new one or get a used flywheel.
I have one.
It may hold for awhile but what a drag if it lets go on your way to the prom.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-29-2007, 08:07 PM
Rickw96's Avatar
I will start looking for a used flywheel. Thanks for all the input.
Rick
Old 03-30-2007, 04:50 AM
