Glyco bearing quality
I have gone thru 4 sets of 3.0 main bearings to find a complete set without some defects in mfg. has anyone else seen the QC slip lately in just about all eng. sizes. I ordered a set from the dealer today and not including the #8 they are almost 900.00 at shop cost !
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 03-28-2007, 06:31 PM
911SCfanatic's Avatar
What are the defects you are finding?
Bill G.
'68 911 Ossi Blue coupe
Old 03-29-2007, 06:13 AM
glyco
The batch I have on the bench now looks like if you painted a wall that had a nial hole in it and the extra paint ran out of the hole and formed a sag, that is what the area out of the oil feed hole in the main looks like and you can feel it, out of the 4 sets all but 3 shells have this problem granted they came from the same supplier and were most likely in the same run at glyco how did QC miss that many ? Some of the mains and rod brgs. from other size engines look as if they were cut on a band saw.
Mike Bruns
Old 03-29-2007, 07:08 AM
abit off center
cgarr's Avatar
You do really need to check everything dont you! Wait til you order a set of ATE Valves
______________________
Craig
G2Performance
Old 03-29-2007, 10:24 AM
Mike:
Without a doubt, Glyco bearing quality isn't what it used to be by long shot. Their QC is questionable at best and the Porsche dealers get the best ones.........
I noticed that Porsche Motorsports provides Vandervell bearings, now.
Some engine builders have gone to American-made engine bearings such as Clevite 77.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-29-2007, 10:33 AM
gtihop's Avatar
I had the same thing with a set of rod bearings purchased from our host. Wayne took care of it right away and sent out another set.
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 03-29-2007, 10:50 AM
Originally posted by Steve@Rennsport
Mike:
do they offer allot for porsche? or is it a bunch of cross referencing?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 03-30-2007, 07:21 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We've noticed the quality dropping for quite a few years now.
That is why every bearing we install is hand sanded with 600 wet/dry and then dry film Moly coated. Although the bearing are not the highest quality we find this method of preparation adequate for even the high output engine requirements.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-30-2007, 09:08 AM
Glyco
Yes we have found the coatings to helpful, but the build up is at least 4/10 of 1000th per shell and with std cranks its not enough clearance for street or track, when we have cranks ground and heat treated we can spec the final size and use the coatings and thats hard to beat.
Thanks, Mike Bruns
Old 03-30-2007, 10:05 AM
They offer nothing for Porsche but Jerry Woods has them do special runs for him. I'd call him and see if they will sell them to you.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-30-2007, 10:33 AM
Re: Glyco
Thanks, Mike Bruns
It has been my experience that almost every used crank that we have removed from a running engine shows some signs of wear. That wear coupled with a micro polish generally renders a crank/rod clearence more than acceptable. The moly coat does add thickness but that thickness is reduced by the burnishing effects during break in.
The moly is force into the pores of both the crank and the bearings making each piece gaul resistant to 170,000 psi when exposed to oil.
Henry Schmidt
Ph: 760-728-3062
Old 03-30-2007, 12:03 PM
abit off center
cgarr's Avatar
Henry,
Are you usiing the Dry-Moly extreme pressure lube? and when used beer is not longer needed
Craig
G2Performance
Old 03-30-2007, 12:22 PM
We actually use Dow Corning 321 Dry Film Lubricant.
It works well in engine to reduced bearing friction.
Beer will still be needed to loosen tight elbows when holding a pool clue.
Henry Schmidt
Ph: 760-728-3062
Old 03-30-2007, 02:22 PM
304065's Avatar
Steve, it turns out that Mahle bought Dana's engine hard parts business, which included Glacier Vandervell.
So there are two camps:
Federal Mogul, which owns Glyco and Goetze and Fel-Pro.
Mahle, which owns Clevite, Vandervell, Victor Reinz.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-17-2007, 11:18 AM
I've used Calico Coatings and know of quite a few builders that use their coated bearings successfully in race applications.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 09-17-2007, 11:57 AM
304065's Avatar
From the Dow Corning 321 datasheet.
To obtain the best adhesion and wear life, apply a coating no more than 0.001-inch thick. A single wet pass of spray usually deposits a film of about 0.0005- to 0.0008-inch thick. Where uniformity is especially important, place parts on a screen during spraying to minimize excessive coating buildup due to “flashback.” Fitting parts on a jig and rotating while spraying also helps.
So let's see here, a coating thickness of 0.0005 to 0.0008 is 0.0127- 0.020mm. So two hundredths of a mm, this looks like a job for the Millimess to see how thick the coating is and how uniformly it's deposited. I suppose some before and after measurements are a good idea too before sanding the bearings.
The bearing shell for a 2,0-2,2 liter engine has a radius equal to the journal diameter plus the running clearance. The high limit of a bearing jounal is 56.990mm. The radius of the tip of the Millimess 1003 has a radius of 1,5mm, this should easily fit inside the bearing's curve.
'81 R65
Old 10-29-2007, 06:28 AM
John,
I bought a can of the 321 to try it out, and it's not the easiest product to apply in a single pass. I obviously need more practice, but I was thinking this stuff might be good for piston skirts for a cheap break-in coating, but the only problem I see is that if you use brake cleaner or denatured alcohol to prep parts, it will wipe the 321 right off.
I personally wouldn't build a tolerance in and accomodate for the thickness of the 321 as it does come off fairly easy - I could see the coating coming off and leaving greater than desired clearances.
Charles Navarro
Old 10-29-2007, 07:36 AM
304065's Avatar
Charles,
I see we are thinking in parallel, my can arrived last week. I was thinking of a couple coats on the bearings to provide startup lubrication and to tighten the clearance with an ablation coating.
Crankshaft to main bearing clearance from p.25 of the little white book: +0.030 to + 0.088 mm.
Henry, can you weigh in here on what the bearings look like after teardown, as they are for a race engine? Is the Molykote still there?
'81 R65
Old 10-29-2007, 08:16 AM
abit off center
cgarr's Avatar
Charles, I just tried some tests with 321 on some old bearings, I cleaned them, applied the coating then put them in my electric furnace at 275, forgot and left them in overnight, well this morning I tried to remove the coating with brake clean and it would not come off.
Craig
G2Performance
Old 10-30-2007, 05:01 AM
banalytic
panama911's Avatar
so... this thread is more than 5 years old now...
Has someone in the meantime disassembled an engine and found the coating with Dow Corning / Molykote 321 still intact?
Or, can you find it filling pores in both crank and bearings, as suggested above?
Or is it just good for break in?
(I'm also thinking of using it on the chain tensioner shafts for an old engine with unbushed tensioners.)
What about heat treatment after application - yes or no?
Lots of questions, but it would be interesting to hear if there is long term experience with the use of 321 in our engines...?
Old 01-06-2014, 08:34 AM
Tags
bearing preparation
