Less brakes, more gas!
Which half to glue??
In Wayne's book, p. 133, figures 3-22 and 3-23 show the internals of the case halves w/ one half having the sealant applied to it. This half is the one with all the studs in it. It occurs to me that putting the sealant on the half with OUT the case studs would be a lot easier than painting the sealant around 24 or so studs... not to mention faster when time seems to be of the essence.
Is there an issue putting it on the other half? I can not think that there is... So is there some assembly trick that makes putting it on the stud side a must do? Didn't I read about someone using a small paint roller to apply sealant with?? Would be hard with all the studs in the way... And the obligatory post-money (I already spent lots) shot: ![]() Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
I think the big problem would be handling the other-side with sealant all over it. The side with the oil pump and intermediate shaft needs to be facing up, so if your trying to lift the other side and maneuver it over the lower half while its got sealant all round the edges and trying not to get your hands in the sealer would be a bit of a pain.
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 |
sealant
You can put the sealant on the 1-2-3 side (without studs) no problem, there are plenty of areas to grab the case as you lower it without disturbing the glue
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
FWIW, If you are using Loctite 574, the sealant does not begin to really cure until the halves are mated - take a reasonable amount of time and don't rush at this stage.
Once the halves are together, do get the nuts\washers\through-bolts installed and torqued in a timely manner.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Thanks gents! That is what I thought, but being the first engine build for me I thought I might just ask.
OK, I need to know, where the heck do you buy those part trays?
Robert Currently Porsche less (but the wife has 2) |
Autozone has the trays, usually near the oil supplies.
Dion
Dion 2002 Boxster S 1999 M3 |
Autozone!! 8.99! Like dion says, in the oil aisle. I bought 2
I friken' looked all over for bakers trays and finally gave up! These are nice. Very light though so they need something under them if you put heavy things on them. Would not carry a crank on one.Best regards, Michael
UFLYICU
Also, I just did this in the last couple of weeks. I did not put any sealant on the journal webs, and my motor is dry as a bone. I only ran a thin bead around the perimiter, and did not smear it to cover the surface. I achieved a beautiful small squeeze-out all the way around with this method. I was very pleased.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
