kirkf's Avatar
How to lower compression on a 3.6
What are the options for lowering compression on a 3.6 964 motor? (to get it down to about 9:1 compression)
Shave pistons? Spacers under cylinders? ??
Kirk
1989 911 Carrera 4 (964)
Old 04-11-2007, 05:05 PM
Kirk:
Don't use spacers as that adversely effects deck height. Increasing deck height increases the propensity for detonation by leaving more end-gas at the perimeter of the chamber near TDC.
Machine the piston domes but you'll not get it to 9:1 without seriously compromising piston strength,..............
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-11-2007, 06:05 PM
WydRyd's Avatar
I've heard of many people machining the domes of the 964 pistons down to 8.5:1 for forced induction application without any dramas, even for up to 1.2bar of boost.
I believe Henry of Supertec has done this many times with great success, as does Protomotive. The 964 piston crowns are very thick. You can't do it with 993 pistons though.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-12-2007, 08:34 PM
kirkf's Avatar
Thanx guys.
Im trying to figure out all the options for installing a supercharger I picked up. Its quite the learning curve!
Kirk
Old 04-12-2007, 09:40 PM
