Manifolds for PMO's
In the attempt to try to save some money, I was wondering if it would be possible to use my 2.2T Zenith Manifolds and Linkage on my carbed 40mm PMO fueled 2.7.
The Heads for the 2.7 are being ported to 38mm. Can the Zeniths be matched?
O22$pa
70 porsche 911t
52 mgtd
Old 05-15-2007, 08:41 AM
No problem at all..
Kind regards
Old 05-15-2007, 08:44 AM
they do get a bit thin after porting, but will work fine. keep an eye out for cracking where the upper and lower flanges join the center tubes.
206 637 4071
Old 05-15-2007, 09:40 AM
sounds good,
How about the Zenith airfilter assembly?
with a new gasket can the air box be put on the PMO carbs just like the original Zeniths?
I like the look of the original air assembly compaired to duel stack K&N assemblies.
O22$pa
70 porsche 911t
52 mgtd
Old 05-18-2007, 08:37 AM
