Eye of the Toiger
matty74's Avatar
Max Mortiz pistons 3.0 - 3.2
Does anyone know anything about Max Mortiz pistons. The pistons take a 3.0 tp 3.2 but I'm not sure what compression ratio
does anyone know?
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 04-17-2007, 04:04 PM
boba's Avatar
They are 9.3 to 1. I have a unused set, ceramic coated.
Old 04-17-2007, 04:22 PM
Eye of the Toiger
matty74's Avatar
what type of cam can I use with these DC 40, DC 60 ?
what sor of config are you running? and HP?
Old 04-17-2007, 05:16 PM
boba's Avatar
Matt,
I did not use the Max Moritz due to a change in build plans so I dont have any data for you. I switched to MFI so went with a MFI p&c from Andial. I still have the MM p&c on the shelf.
Bob
Old 04-17-2007, 05:25 PM
Eye of the Toiger
matty74's Avatar
Can you use MFI with these I read that they can't take too agressive cam shaft
Old 04-17-2007, 06:31 PM
boba's Avatar
Not the optimum for MFI, that is why I changed, plus a bump in CR. CIS will not take much overlap.
Old 04-17-2007, 06:41 PM
Eye of the Toiger
matty74's Avatar
Bruce Andersen states that with the MM pistons a GE40 or an S cam will give significant power increase used with webers.
Now I have DC60 and MFI, because of the overlap on S cams or modified S in my case Bruce reckons that Additional valve clearance is required, does he mean machining the pistons to get the required valve clearance?
Old 04-18-2007, 03:06 PM
max moritz pistons
46mm webers, max moritz pistons ge80 camshafts=
370 hp 260 torque
Old 04-23-2007, 11:32 AM
gestalt1's Avatar
Re: max moritz pistons
370 hp 260 torque
that must be a typo! 270-300hp is more likely.
Old 04-23-2007, 01:27 PM
max moritz pistons
Look at the graph in bruce anderson's book 911 performance
370hp
Old 05-16-2007, 10:26 AM
gestalt1's Avatar
were both wrong, on page 152 the chart shows about 330hp, 260lb/ft. the pic below is of my mahle 98mm piston/cylinders. the top is a dome type for carbs or mfi, the CR is 9.5:1. the valve pockets were plenty deep for DC62 cams, i'm sure a GE80 would work also. hope this helps.
Old 05-16-2007, 04:12 PM
boba's Avatar
These are the Mahle 98mm 10.3:1 for MFI.
Old 05-16-2007, 04:39 PM
shbop's Avatar
What was the part number for these 9.5:1's? What heads are you using? Thanks in advance.
Jon
Old 05-17-2007, 08:37 PM
