gumba's Avatar
46mm Weber jetting for a 3.2
I'm converting my 3.2 to 46mm Webers & crank fire ignition. Anyone with a similar set can tell me their carb set up?
venturies:
main:
air correctors:
Also total advance on the ignition. It's a Electromotive HPV-1.
I'm using SSI's and sport muffler for the exhaust.
I'll fine tune it with an LM-1, I'm looking for a basic set up to get going.
thanks.
Old 04-26-2007, 09:46 PM
Hi:
I can make some suggestions but I need more information,...
Cams???
Compression ratio???
Using 91 octane gas???
Once I have all that, I'll offer some suggestions.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-26-2007, 10:02 PM
gumba's Avatar
Hi Steve,
It's a stock '86 US 3.2, using 91 ocatne.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 04-26-2007, 10:29 PM
I'd start with:
38mm venturies
160 main jets
180 correctors
60 idles
Make sure the fuel pressure is at 3.5 psi and the float levels are PERFECT.
For the HPV-1:
You need to be conservative since that 91 octane gas is marginal in hot weather. Use no more than 30 degrees total and around 18-20 degrees at 3K. Less is More when using CA pump gas,.....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 04-27-2007, 12:25 AM
gumba's Avatar
Great, thanks.
Harold
Old 04-27-2007, 07:28 AM
