Finally Dyno'd the 2.6
Well, I finally got over to the shop to dyno the 2.6 last week. In the fall, it was running really lean at the upper end. So after winter hibernation, I swapped some jets and got it pretty evened out.
Engine is a 2.6: Early aluminum case 66mm Counterweighted Crank 92mm Mahle P&C 2.2S Heads Early S Cams 40 mm Webers Twin Plugged with a Supertec distributor + Burns-Bros rotor Standard early heat exchangers Standard 2 in 1 out muffler Dyno chart - DIN HP, at wheels, corrected for altitude. http://forums.pelicanparts.com/uploa...1178851314.gif AF Ratio http://forums.pelicanparts.com/uploa...1178851362.gif |
Nice torque curve! I suspect you might pick up a bit on the low end if you can lean out the fuel curve at 3K. I can't tell if this is from accel pumps dumping too much fuel or the transision from idle to main jets.
I bet it revs very quick! |
I was actually suprised at the torque curve myself - I was thinking it would be a bit peakier with the S cams. I may go down '5' in the size of main jets and see what that does to the AF ratio.
And yes, it revs like crazy! :) AM |
I for got to add - the 3k rich is the accel jets - I'm going to back them off just a bit.
| All times are GMT -8. The time now is 02:01 PM. |
