andrew15's Avatar
Finally Dyno'd the 2.6
Well, I finally got over to the shop to dyno the 2.6 last week. In the fall, it was running really lean at the upper end. So after winter hibernation, I swapped some jets and got it pretty evened out.
Engine is a 2.6:
Early aluminum case
66mm Counterweighted Crank
92mm Mahle P&C
2.2S Heads
Early S Cams
40 mm Webers
Twin Plugged with a Supertec distributor + Burns-Bros rotor
Standard early heat exchangers
Standard 2 in 1 out muffler
Dyno chart - DIN HP, at wheels, corrected for altitude.
AF Ratio
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 05-10-2007, 07:45 PM
I would rather be driving
jpnovak's Avatar
Nice torque curve! I suspect you might pick up a bit on the low end if you can lean out the fuel curve at 3K. I can't tell if this is from accel pumps dumping too much fuel or the transision from idle to main jets.
I bet it revs very quick!
Old 05-11-2007, 07:22 AM
andrew15's Avatar
I was actually suprised at the torque curve myself - I was thinking it would be a bit peakier with the S cams. I may go down '5' in the size of main jets and see what that does to the AF ratio.
And yes, it revs like crazy!
AM
Old 05-11-2007, 06:04 PM
andrew15's Avatar
I for got to add - the 3k rich is the accel jets - I'm going to back them off just a bit.
Old 05-11-2007, 06:05 PM
