Manifolds for PMO's
In the attempt to try to save some money, I was wondering if it would be possible to use my 2.2T Zenith Manifolds and Linkage on my carbed 40mm PMO fueled 2.7.
The Heads for the 2.7 are being ported to 38mm. Can the Zeniths be matched?
O22$pa 70 porsche 911t 52 mgtd |
No problem at all..
Kind regards David |
they do get a bit thin after porting, but will work fine. keep an eye out for cracking where the upper and lower flanges join the center tubes.
sounds good,
How about the Zenith airfilter assembly? with a new gasket can the air box be put on the PMO carbs just like the original Zeniths? I like the look of the original air assembly compaired to duel stack K&N assemblies.
