brindleg
Guest
Posts: n/a
Unhappy Air Delectors
Following the directions in the Haynes manual. I did not install the air delectors and now have the cam covers and rockers installed. Do I really need the air dlectors and if so is there a way to install them now that the oil return tubes are in place? Is there a mod to connect the front and back air deflectors and cover the whole side? Suggestions?
Old 05-21-2007, 11:59 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec has 906 style air deflectors that can be installed any time during the assembly process.
They have better cooling properties and are reasonably price.
Please check with our host Pelican Parts to see if you can purchase these items direct from them.
As always, we aim to help but would not wish to intrude on the sale of any item, part or information offered by our generous host.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-21-2007, 06:10 PM
Less brakes, more gas!
euro911sc's Avatar
Those are pretty cool Henry! 4 'T' items per side?
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-21-2007, 06:41 PM
-Michael
Yes
Henry Schmidt
Ph: 760-728-3062
Old 05-21-2007, 07:20 PM
Your only other choice is to either remove the heads again (they can be removed as a set of 3 and keep the cam towers attached), or to put in the collapsable oil return tubes. Running without air deflectors is not an option.
-Andy
Old 05-21-2007, 09:48 PM
