2.0 L twin plug racing engine re-visited
I finally got my pistons back from the machine shop to correct my piston to valve clearance.
I just need to install the wires, no hurry, this is next seasons engine. I will drop down from CP3 (2.5L) to CP (2.0L). This engine should be a high reving, torquey engine.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
That's a wonderful job !
what's up with the exhaust system ? |
Constitutional Liberal
Can you post the sheets so we can see this amazing result. Flat collectors like Porsche used produced 220 hp in the racing 2.0 engines. That must mean you're making over 230. That's quite an impressive number. There is an official 911 dyno thread just started, these two+ dyno runs would be a great addition. Thanks in advance
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Once I put the engine in I will feel a big difference under my foot, concidering my "other" 2.0L was mild. The "new" 2.0L has a different cam DC80, twin-plugged and a bump in CR from 10.1:1 to 10.6:1. I may get this to a chassis dyno but I normally dont dyno them. I know, I know I should be dyno-ing, but I use the old way., take it to the track, mess w timing and jetting and leave it at that.
All Wired up. Thanks JBracing for the help and support.
wow i didnt know a 2.0l could put out that much, but then agin i dont really know much about porsche right now. I have a question whats the unit towards the back of the engine in the middle with the red cap and what do the two connections go to?
"Work harder........... Millions on welfare depend on you" " If you aint cheaten you aint tryin" |
Crankcase breather, a hose goes from it to the oil tank.
Mark, nice looking motor! Is that the same exhaust that "plavan" uses? Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
what about the two brass conections do they plug up to something?
Oil pressure sender.
Cheers
