126coupe's Avatar
2.0 L twin plug racing engine re-visited
I finally got my pistons back from the machine shop to correct my piston to valve clearance.
I just need to install the wires, no hurry, this is next seasons engine. I will drop down from CP3 (2.5L) to CP (2.0L).
This engine should be a high reving, torquey engine.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 05-21-2007, 02:13 PM
That's a wonderful job !
what's up with the exhaust system ?
Old 05-21-2007, 11:47 PM
126coupe's Avatar
Its a custom exaust made by Becks in Arizona. Made 10-12 more HP on the dyno. It has a completely different "note"
28' Pace Trailer
Old 05-22-2007, 07:29 AM
Constitutional Liberal
Turbo_pro's Avatar
WOW 10-12 horse power.
Can you post the sheets so we can see this amazing result.
Flat collectors like Porsche used produced 220 hp in the racing 2.0 engines. That must mean you're making over 230. That's quite an impressive number.
There is an official 911 dyno thread just started, these two+ dyno runs would be a great addition.
Thanks in advance
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 05-22-2007, 01:39 PM
126coupe's Avatar
Thanks in advance
I just took Becks word on the 10-12HP increase.
Once I put the engine in I will feel a big difference under my foot, concidering my "other" 2.0L was mild. The "new" 2.0L
has a different cam DC80, twin-plugged and a bump in CR from 10.1:1 to 10.6:1.
I may get this to a chassis dyno but I normally dont dyno them. I know, I know I should be dyno-ing, but I use the old way., take it to the track, mess w timing and jetting and leave it at that.
28' Pace Trailer
Old 05-22-2007, 03:27 PM
126coupe's Avatar
All Wired up. Thanks JBracing for the help and support.
28' Pace Trailer
Old 05-22-2007, 03:51 PM
RichF's Avatar
wow i didnt know a 2.0l could put out that much, but then agin i dont really know much about porsche right now. I have a question whats the unit towards the back of the engine in the middle with the red cap and what do the two connections go to?
"Work harder........... Millions on welfare depend on you"
" If you aint cheaten you aint tryin"
Old 05-22-2007, 08:23 PM
Jeff Alton's Avatar
Crankcase breather, a hose goes from it to the oil tank.
Mark, nice looking motor! Is that the same exhaust that "plavan" uses?
Cheers
www.turn3autosport.com
Old 05-22-2007, 08:50 PM
126coupe's Avatar
Cheers
Thanks! Chad Plavan uses a different exaust system, his cousin JP uses the same system.
28' Pace Trailer
Old 05-23-2007, 03:43 AM
RichF's Avatar
what about the two brass conections do they plug up to something?
Old 05-23-2007, 04:48 AM
126coupe's Avatar
Oil pressure sender and oil pressure light
28' Pace Trailer
Old 05-23-2007, 08:26 AM
Jeff Alton's Avatar
Oil pressure sender.
Cheers
