Garage dweller
Help with plug gap
For various reasons I want to try a set of NGK plugs, I am also unsure of the plug gap that the original builder settled on when he used Bosch coppers.
Please help me get a good starting point or at least point me in the direction that will help me learn a good starting point. Through search of this sight a have a new set of NGK BP8ES plugs. The engine: 2.7 with RS P&Cs, matched and ported heads S cams 40 webers Permatune The engine is very well sorted - with the only real change of late being new plugs (Bosche platinum) - engine isn't running bad....but it does not seem as "crisp" Autox and track day car Thanks in advance guys! Don
Don Sjolin IIIEURO AUTOWERKS 616.874.7932 |
I run my NGK BP7ES at .036 and they run great.
'75 911S Silver Anniversary #164(Formerly JTO's) Rebuilt 2.7 with full ARP, 9:1 CR. SSI, GHL, ER polybronze bushings, finned oil lines. Lowered and corner balanced. CIS retired, now PMOs! '65 912 slate gray sunroof (driving project) |
Garage dweller
Don
I use BP7ES at about 1.3mm and they work great.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Garage dweller
Thats quite a bit larger than the .036 quoted above. I installed the BP8ES at .036 last night - all I was able to do was start up and idle last night (being kind to my neighbors). I have an autocross this weekend - we'll see how they work. Anyone have a good source to read up on how to evaluate gap in order to determine if a change +/- should be tested? just curiosity Don
Your coil type will dictate the gap. I assume that you run a stock coil so you should keep gap at stock specs. If you were running coil packs then you can run .05 gap. Over-gapping a plug usually results in over heating the coil.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
At the end of my journey thru the tuning of my 2.7, I found an MSD 6AL, MSD Hi-vibration coil, 8.5 mm Magnacore wires, & NGK BP7ES plugs gapped at .05....humpf, where did that stuff come from?
I have 9.7:1 compression, Solex cams ( great AX cams, I've found), & the infamous Webers. It's been trouble free for 5-6 years...he said while knocking wood.
JPIII Early Boxster |
2.2E stroked to 2.4E
Webers BP6ES @.045 Crane XR3000 Ignition PS-91 coil Clewett Wires 9.6:1 Compression E cams Over 165 HP at the wheels
Matt 72 911T Targa - Sold Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat. Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!! |
