Sweet. What about the gearbox. Did the 72 have the 915 gearbox or the 901 gearbox. Is the 901 gearbox good for 200+ HP?
1970 911 T
2004 Carrera 4S
Old 06-07-2007, 10:59 AM
915. Henry went thru it and replaced the synchros etc. However, since the car sat for many years with a hole in the #4 cylinder, the mileage on the trans was only 54K. Seems to handle the power no problem.
1972 911T/S MFI Survivor
Old 06-07-2007, 11:02 AM
I wonder if the 901 gearbox could handle 200 HP?
1970 911 T
2004 Carrera 4S
Old 06-07-2007, 11:03 AM
Having driven a 912 with the 901, I would preserve it if at all possible.
Old 06-07-2007, 07:25 PM
In the 914 community there are quite a few folks running 200-240hp competitively with stock 901 box's.
Now we've a slight advantage over the 911 configuration as the output drive turns towards the solid side of the 901 case.
Its not unheard of for the v8 & Subaru conversion crowd to run stock 901 at above 300hp but most those guys forgo 1st gear.
In the long run if your considerate on your equipment there's no reason why a 901 shouldn't withstand 200 ponies. I.e limit your burnouts :-)
Old 06-08-2007, 10:19 AM
Use a billet intermediate plate,don't "Dairy Queen" the clutch, and that 901 will handle 300HP. The 901 is a good shifting, lightweight tranny for a small bore motor. I see them hooked to 3.2 engines all the time and they last a long time. Lock out 1st, use second through 5th, and it will live behind a Small block Chevy motor.
Definition: "Dairy Queen the clutch" - A high RPM drop of the clutch so that the wheels break traction causing lots of smoke to impress the girls sitting at the Dairy Queen.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 06-12-2007, 08:44 PM
No - Henry Schmidt
Started at around 8-ish, but with a couple of changes, addl detailing, new front oil cooler with lines through the chassis, etc , I think it ended up in the 9's. I thought it was well worth the $$. Only remaining issue is the MFI.
The car runs awesome - but very rich. And while I know htis is supposed to be normal, I do worry a little about gas in the oil, and the wife and kids don't like the smell when we're at a stop light, etc. Of course, I just love the performance.
I am planning to put it on Loren Begg's dyno when I get the time as I was told by some that at higher revs the T MFI is probably getting a little lean.
Did you upgrade your oilpump or still using the 2.2t one?
Old 09-03-2023, 07:09 PM
The 9 Store
16 year old thread.
All used parts sold as is.
Old 09-03-2023, 07:21 PM
Wow - I had completely forgotten about this thread. I don't think I upgraded the oil pump but I will check my paperwork and update.
Old 09-05-2023, 10:10 AM
Much appreciate, thanks 🙏
Old 09-06-2023, 12:26 PM
