Mark S
cam timing one side should I use spec other side.
Took off cam tower one bank 911. Cams are Elgin, lost timing spec years ago. I know I can call Elgin and get specs question, should I use the other cam as reference and time off that. My reasoning is I would know exactly what I have and match it to side on reinstalling.
Old 05-30-2007, 09:42 AM
304065's Avatar
If you can call Elgin, you should. Just because the other cam is in a certain position doesn't mean it's right.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-30-2007, 12:23 PM
camgrinder's Avatar
Whats the part number?
John Dougherty
Dougherty Racing Cams
Old 05-30-2007, 12:52 PM
Mark S
Good point John. I originally installed them, that should have been a BIG red flag right there. CG, Elgin # 310/296.
Old 05-30-2007, 02:56 PM
camgrinder's Avatar
Use 6.2 mm and you have a PM.
John Dougherty
Old 05-30-2007, 03:10 PM
Mark S
Got it John, thank you. PMed you back. Mark
Old 05-30-2007, 04:51 PM
Mark S
Need help Mr. Doughherty.
Per you suggestion I checked 4-6 cam and measured 0.2650" TDC overlap. You said time 6.2MM which is 0.2441" Would you consider this to be acceptable and time the 1-3 side I pulled to 0.2650 to match or do I need pull apart and retime 3-6 to 0.2441/6.2MM. Thank you.
Old 06-21-2007, 03:55 PM
camgrinder's Avatar
I would set them both at 6.2 mm. .265" is too far advanced.
John Dougherty
Old 06-21-2007, 04:04 PM
