I have started my search for an engine for my 914 hot rod project and came across the following: 1988 3.2 with all intake and exhaust, no DME or harness with aprox. 200k miles with leakdown numbers of 4-8% cold. This engine turns over freely with no nasty noises and is available for 4k. I am not planning on a rebuild right away so I'm hoping the engine can be installed "as is " and drive it for a year or two and then do a rebuild as needed. This will be a weekend autocross rat and DE car. Thoughts? I think I'm ready to pull the trigger but wanted some feedback from others.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Anyone???
OCD project capitan
Sounds like a great deal... my only question is how much is the DME & harness going to cost? Otherwise, great power plant for these cars.
Don Welch '73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper. |
I would rather be driving
Forget the DME. Sell the intake and put a set of carbs on it. Swap the cams out and really enjoy that teener.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Carbs are a great idea for that engine. I wouldn't swap cams though until you're ready to rebuild the engine. With the proper exhaust you are looking at 250 plus HP with just the carbs (46mm).
-Andy
72 Carrera RS replica, Spec 911 racer |
Irrationally exuberant
At that mileage I'd consider it closer to a "core", not a "2 years of trouble free driving" proposition. Used DME's turn up now and then but used 3.2 harnesses are pretty rare - I guess people want them with the motor usually.
I expect to sell my own ~120K '89 3.2L motor with harness and DME for around $5000 (but not this year). You judge whether a 200K motor (minus $500 DME and unobtainable harness) is worth $4000. Now if your leaving something out - like it was rebuilt at 160K with new P&C, etc that would be different of course. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chris I consider this a runnable core if that makes sense. It has not been rebuilt that the seller is aware of but it did come out of a running California car for what ever that's worth. I'm pretty sure I would sell off the EFI parts and go PMO's as I have done on my SC. I think it's worth taking a chance for the price but wanted to get some opinions. From reading this forum and others it looks like re-ringing and new valve guides normally brings these back to health,assuming you don't go crazy " while you're in there". After all this will mostly be a weekend car.
If I decide to purchase this engine and run carbs can the distributor be used? I assume the ECU drives the distributor? If no ECU then what drives the distributor? Or what distributor can be used in its place?
You need a different system for the ignition. Crankfire is an easy way to go. I don't know what other distributors would work on a Carrera.
-Andy
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Well it doesn't matter now the seller just informed me he is keeping the engine. Oh well the search continues.
And now the seller says he may honor our deal. I've asked the seller to take a week to figure out if he really wants to sell this engine. If after the week he want to sell I'll grab it. Ben I'll let you know at that point on the injection.
