-   -   valve adjustment tool (http://forums.pelicanparts.com/911-engine-rebuilding-forum/350212-valve-adjustment-tool.html)
jtkkz 06-04-2007 11:06 AM
Is there a valve adjustment tool that is like a dial guage type?
304065 06-04-2007 11:46 AM
Yes, the standard Z-block and dial indicator can be mounted with the tip of the indicator resting on the jam nut for the elephant's foot adjuster. You zero the gauge with the adjuster pressed up against the tip of the valve stem, then push on the rocker pad to open the gap. The indicator should move and show you how much of a gap there is, 0.1mm in the case of a 911.
More here:http://forums.pelicanparts.com/showthread.php?s=&threadid=213279&highlight=valve+ adjust+dial+indicator
Tom '74 911 06-04-2007 01:07 PM
The thought of being that accurate is appealing. Could you show me exactly where the tip of the dial indicator should be set and where you'd push the rocker pad?
Thanks,
Tom
http://forums.pelicanparts.com/uploa...1180987639.jpg
euro911sc 06-04-2007 07:39 PM
Here:
http://forums.pelicanparts.com/uploa...1181011170.jpg
At least that is where I do it.
Best regards,
Michael
Tom '74 911 06-05-2007 09:04 AM
Thanks Michael -
That's what I suspected, but just wanted to be sure I was visualizing correctly.
Tom
cstreit 06-05-2007 07:26 PM
Geez I know it's accurate, but doesn't this add HOURS to your valve adjust?
euro911sc 06-06-2007 08:08 AM
Yes... and no... at least for me, I'm just not very good with the feeler gage and getting #6/#3 intake is a real PITA when its in the car. With the dial I don't have to contort so much. For the most part, I'm not in a hurry either and no one is paying me except myself ;)
Best regards,
Michael
