jtkkz's Avatar
Question valve adjustment tool
Is there a valve adjustment tool that is like a dial guage type?
Old 06-04-2007, 11:06 AM
304065's Avatar
Yes, the standard Z-block and dial indicator can be mounted with the tip of the indicator resting on the jam nut for the elephant's foot adjuster. You zero the gauge with the adjuster pressed up against the tip of the valve stem, then push on the rocker pad to open the gap. The indicator should move and show you how much of a gap there is, 0.1mm in the case of a 911.
More here:Dial Guage for Valve Adjustment
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-04-2007, 11:46 AM
Tom '74 911's Avatar
The thought of being that accurate is appealing. Could you show me exactly where the tip of the dial indicator should be set and where you'd push the rocker pad?
Thanks,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 06-04-2007, 01:07 PM
Less brakes, more gas!
euro911sc's Avatar
Here:
At least that is where I do it.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-04-2007, 07:39 PM
Thanks Michael -
That's what I suspected, but just wanted to be sure I was visualizing correctly.
Tom
Old 06-05-2007, 09:04 AM
Super Moderator
cstreit's Avatar
Geez I know it's accurate, but doesn't this add HOURS to your valve adjust?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-05-2007, 07:26 PM
euro911sc's Avatar
Yes... and no... at least for me, I'm just not very good with the feeler gage and getting #6/#3 intake is a real PITA when its in the car. With the dial I don't have to contort so much. For the most part, I'm not in a hurry either and no one is paying me except myself
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 06-06-2007, 08:08 AM
