In my search for an engine for my project car I have found the following: a 1971 911T engine that has had all the machining done ( flat ground case,line bore, etc. ) by CE and it has a 2.7 crank,rods with 84mm Biral cylinders with S pistons and E cams. I believe this makes a 2.4 litre? Anyway it appears to be a well done long block that needs assy. I'm guessing this is a 170-180 horse engine? Also has had oil bypass done and has a 3.0 oil pump. What are your thoughts on this setup for a AX/weekend car?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Sounds great. I think you are right on with the power estimate and much better torque curve than a 2.4S engine.
-Andy
72 Carrera RS replica, Spec 911 racer |
