LinkBack | Thread Tools | Rate Thread |
Chain fence eating turbo
Will GT2 Evo cams clear 7.5:1CR, 98mm Max Moritz pistons on a 3.2 (3.4)?
I have a 3.2 converted to 3.4 using the Max Moritz flat-top pistons. I believe these are 7.5:1CR with 3.2 heads?
Will the GT2 Evo's clear? If not, what should the fly-cut depth be? They already have divots from my mechanical overrev, so more than likely will already clear. ![]() Just want to make sure if the stars align, and I find a pair. Second question, is there GT2 and GT2 Evo variants? Any info would be great. I plan on running sub-7kRPM. Low speed torque is not a concern having a G50.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Do you have pictures of the pistons?
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Hello Josh, this is about the best I have that I can quickly pull:
Not sure why my photo did not make it to the last post...
My MM pistons are pretty flat. No valve reliefs like yours. I cannot tell if your reliefs are below the crown surface or not?
21's have more lift than GT2's according to DRC's.
Are they made by Mahle? I didn't know MM did a turbo upgrade.
Was told they were here either by a symbol or part number
Banned
Cory, I can't help with your questions, but just wanted to give you props for your hilarious use of the rockers!
![]() Also, not to be an alarmist, but with dents like like put in the piston crowns, wouldn't it be a good idea to have the rods and crank checked for damage (maybe you've already planned on that)? Last edited by Ronnie's.930; 08-21-2015 at 11:07 PM.. |
BTW, fly-cutting the pistons would have removed material, this method (piston kissing exhaust valves) acted more billet. ![]() If anyone believes opposite, well, I'll be the guinea pig for long term longevity (or catastrophic failure).
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 08-22-2015 at 02:41 PM.. |
