Addicted to Racing
edbaus's Avatar
930 piston and cam questions
I have a 930 3.3 from my 79.
I am currently running the stock pistons and an sc cam.
I pulled the motor apart because I spun a rod bearing. What I found is that all of the intake valves have at least touched the pistons.
I had no idea that I needed to recess the pistons for the sc cam.
My next step is to use a pair of 935 camshafts with the motor. Now, with what I have found. I am assuming that I am going to have to have the pistons fly cut. Or use different pistons.
Hate taking even more material out of the combustion chamber to give even less of a compression ratio.
What have others done. Should I stick with the sc cams.
btw, the rest of the setup is electromotive tec3, twin plug, carrera intake, twin turbo using 993 heat exchangers.
Ed
Old 06-24-2007, 07:41 PM
North Coast Cab's Avatar
I would have JE make custom pistons so you'll have valve clearance and keep the desired compression. It's only money!
1985.5 944 GTS
Old 06-25-2007, 09:52 AM
