Engine Yoke - What is Good?
I'm looking around and I have found several options for engine yokes, because I obviously want to mount my engine properly.
One is this custom made yoke which you can buy from an ebay store for about usd $200. It looks like it has to be welded onto the stand, which I am hesitant to do, as well, I wouldn't want to trust my engine to this, unless someone else instantly knows of this make...
Another is the OEM Porsche yoke, which is prohibitavely expensive almost, so it is only a last resort.
The most intriguing one I have found so far, is the yoke made by mainlycustom by design. It's merely a ring which affixes onto a universal stand to imitate the OEM yoke. Does anyone have any comments on that one?
Also, does anyone have any general advice or recommendations for me, or other alternatives?
Thanks again in advance!!
Ian
'82 Volvo 245: Daily Driver
'74 911 : WIP
Old 07-05-2007, 11:13 AM
Scott R's Avatar
I used the universal ring for my entire rebuild, worked like a champ.
Only problem is that you can't clear the heat exchanger pipe on the end of the heat exchanger.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-05-2007, 02:16 PM
By universal mount, do you mean the one from mainly custom or another one?
'74 911 : WIP
Old 07-05-2007, 04:02 PM
Less brakes, more gas!
euro911sc's Avatar
I've got the mainly mount with a harbor freight stand. Works fine. The only issue I have had is trouble with the XZN tool fitting on the fly wheel bolts. I had to use a box wrench over the tool I got. If you bought the whole mount it provides more room to get a socket wrench in there.
Only other issue was some slight interference with my stock SC exhaust parts, but nothing to worry about really.
If you do not have any other special tools you might consider the too super kit. I did and then I found a variety of used tools over the span of a year... Depends on your budget.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 07-05-2007, 04:18 PM
Super Moderator
cstreit's Avatar
SIR tools engine mount has served me well for years and many engines... Our host here at PelicanParts sells it.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Scott R's Avatar
I don't know the manufacture, I used the this one:
http://www.pelicanparts.com/catalog/shopcart/PORS/POR_PORS_PTOOLS_pg2.htm#item9
Purchased from our gracious host, Pelican. In fact to avoid getting the wrong this it's probably best to just buy it here.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-05-2007, 04:22 PM
3 restos WIP = psycho
kenikh's Avatar
Do a search; this thread has been covered ad nauseum. There are pros and cons to using a universal. All cons on a mag case.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-05-2007, 05:16 PM
i just used the ring that adapts to the universal mount. i was unable to rotate the engine with the heat exchangers in place. i borrowed the ring from a friend, so i wasn't out the money, but if i had purchased it, i would be returning it to upgrade to the fully welded piece:
http://www.pelicanparts.com/catalog/images/Tools_folder/tools_porsche_eng_stand.JPG
Matt
72 911T Targa - Sold
Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat.
Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!!
Old 07-06-2007, 01:00 PM
vinny c's Avatar
PEL-TOL-P201
Engine Holding Fixture P201 (made in Europe) [Photo]
$199.00 from our host
Old 07-07-2007, 06:49 PM
Some answers here.
Engine Stand Adapter Ring How TF?
Old 07-08-2007, 10:49 PM
