-   -   Cold compression test (http://forums.pelicanparts.com/911-engine-rebuilding-forum/356847-cold-compression-test.html)
safe 07-12-2007 02:00 AM
Hi
I know that a compression test should be done on a warm engine, but yesterday I did one for the first time when I changed my plugs, see thread http://forums.pelicanparts.com/showthread.php?threadid=356768.
But does a cold test have any value?
I got some pretty lousy results (I'm at sea level):
#1 110 psi
#2 140
#3 140
#4 120
#5 142
#6 110
Then I put some oil in the cylinders
#1 130
#2 150
#3 150
#4 135
#5 145
#6 142
But I don't know if the oil sealed bad rings or just a cold engine, do I?
And yes, I should probably perform a proper leak down test.
afterburn 549 07-13-2007 08:03 AM
Why not do a hot comp. test ????
safe 07-13-2007 11:47 AM
Convenience, I had all plugs removed...
