safe's Avatar
Cold compression test
Hi
I know that a compression test should be done on a warm engine, but yesterday I did one for the first time when I changed my plugs, see thread sparkplug reading help.
But does a cold test have any value?
I got some pretty lousy results (I'm at sea level):
#1 110 psi
#2 140
#3 140
#4 120
#5 142
#6 110
Then I put some oil in the cylinders
#1 130
#2 150
#3 150
#4 135
#5 145
#6 142
But I don't know if the oil sealed bad rings or just a cold engine, do I?
And yes, I should probably perform a proper leak down test.
Magnus
Old 07-12-2007, 02:00 AM
Air Medal or two
afterburn 549's Avatar
Why not do a hot comp. test ????
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 07-13-2007, 08:03 AM
safe's Avatar
Convenience, I had all plugs removed...
Magnus
Old 07-13-2007, 11:47 AM
