3.0 to 3.2 upgrade questions
My 79SC 3.0L has 146K and is beginning to show its age. I recently rebuilt a 87 Carrera and found 6 niksil in spec pistons and cylinders so I have found myself with a set of alusil P/C. The Carrera O/H was due to a broken stud.
It looks like from what I read here that this is a good upgrade and with a 964 grind and my current CIS will give some real gains. What are the problems with this upgrade? Any mods to the case necessary? Are Carrera rods necessary? Thanks |
Re: 3.0 to 3.2 upgrade questions
95 mm 3.2 pistons are not a direct replacement for 3.0 pistons. To use the 3.2 95mm pistons on a 3.0 crank you must offset the wrist pin .030 to account for the wrist pin height difference. 3.2 Carrera rods will not fit a 3.0 crank. Reusing Alusil is always a gamble. Good luck. |
How does a 3.2 get its displacment increase if the cylinders are the same? How do you make a 3.0 into a 3.2 with what I have? Sounds like I can't. Is the 3.2 P/C cylinder set I have worth anything or should I junk em?
Re: Re: 3.0 to 3.2 upgrade questions
Thanks for your response. |
The displacement increase on the 3.2 is due to the longer stroke of the 3.2 crankshaft relative to the 3.0 crank. Pistons for both are 95mm.
Going from a 3.0SC to a 3.2 requires new, larger pistons and cylinders. |
Going to 3.2 with a 3.0 crank requires going to 98mm pistons (designed for a 3.0 crank) and cylinders. This gives you a 3.2 engine but with a shorter stroke than the Carrera 3.2.
Can you put a 3.2 crank in a 3.0 case?
| All times are GMT -8. The time now is 11:02 PM. |
