OldTee's Avatar
3.0 to 3.2 upgrade questions
My 79SC 3.0L has 146K and is beginning to show its age. I recently rebuilt a 87 Carrera and found 6 niksil in spec pistons and cylinders so I have found myself with a set of alusil P/C. The Carrera O/H was due to a broken stud.
It looks like from what I read here that this is a good upgrade and with a 964 grind and my current CIS will give some real gains.
What are the problems with this upgrade? Any mods to the case necessary? Are Carrera rods necessary?
Old Tee
all 911s sold
Old 07-17-2007, 09:20 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Re: 3.0 to 3.2 upgrade questions
Cylinders are a direct replacement.
95 mm 3.2 pistons are not a direct replacement for 3.0 pistons.
To use the 3.2 95mm pistons on a 3.0 crank you must offset the wrist pin .030 to account for the wrist pin height difference.
3.2 Carrera rods will not fit a 3.0 crank.
Reusing Alusil is always a gamble.
Good luck.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-18-2007, 07:26 AM
OldTee's Avatar
How does a 3.2 get its displacment increase if the cylinders are the same? How do you make a 3.0 into a 3.2 with what I have? Sounds like I can't. Is the 3.2 P/C cylinder set I have worth anything or should I junk em?
Old Tee
all 911s sold
Old 07-18-2007, 08:57 PM
OldTee's Avatar
Re: Re: 3.0 to 3.2 upgrade questions
How do you do this?
Thanks for your response.
Old Tee
all 911s sold
Old 07-18-2007, 09:01 PM
The displacement increase on the 3.2 is due to the longer stroke of the 3.2 crankshaft relative to the 3.0 crank. Pistons for both are 95mm.
Going from a 3.0SC to a 3.2 requires new, larger pistons and cylinders.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 07-19-2007, 02:41 AM
sjf911's Avatar
Going to 3.2 with a 3.0 crank requires going to 98mm pistons (designed for a 3.0 crank) and cylinders. This gives you a 3.2 engine but with a shorter stroke than the Carrera 3.2.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 07-26-2007, 09:55 PM
North Coast Cab's Avatar
Can you put a 3.2 crank in a 3.0 case?
1985.5 944 GTS
Old 07-27-2007, 01:29 PM
Originally Posted by OldTee View Post
How do you do this?
Send the rods to a quality machine shop.
Henry Schmidt
Ph: 760-728-3062
Old 07-27-2007, 01:40 PM
Yes
Henry Schmidt
Ph: 760-728-3062
Old 07-27-2007, 01:41 PM
