-   -   2.7 Race Motor Case Work (http://forums.pelicanparts.com/911-engine-rebuilding-forum/357838-2-7-race-motor-case-work.html)
North Coast Cab 07-18-2007 02:09 PM
Can someone give me a rundown of the recommended case work (estimates would be great too) for the case work need to build up a 2.7 race motor?
TIA, John
Eagledriver 07-18-2007 04:45 PM
I don't have prices but the list should include:
Install Casesavers on all headstud holes
Install timecert on through stud at intermediate shaft.
Shuffle pin
Align bore
Spot face throughbolt holes.
Clean case and clean out all oil passages.
You should only use a 7R case and if you use a 2.4 case you'll neet to bore out the spigots.
I'm gussing this will cost a minimum of 1500 dollars and probably more like 2000 dollars all together.
-Andy
ChrisBennet 07-18-2007 08:16 PM
This spring I had a 2.7 case resized back to standard (much better than line boring), case inserts, spigots cleaned up and the through holes chamferred on the non-chamfered side by Ollies. Cost around $1000. I don't know how much more it would be for shuffle pinning.
-Chris
Steve@Rennsport 07-18-2007 10:49 PM
Hi John:
Andy's estimates are darned close,....:) I also do the oil bypass modification and have the case parting halves machined flat and the main bearing saddles lined bored back to standard. This ensures a true bore so the crank doesn't bind when everything is torqued up.
We also modify the main bearing oiling, main bearing shells, and cross-drill the crank before all the other preparation on that item.
I spend around $ 1900 for all the necessary case mods for a mag-cased race engine.
Take note than I do not boattail the mains on magnesium cases,...:) :)
North Coast Cab 07-19-2007 05:50 AM
Thanks. I have an old 2.7 longblock that I've been kicking around as a spare or enduro motor or something. Problem is these damn 2.7's cost too much money to get into good shape.
dweymer 07-19-2007 06:04 AM
wanna sell the case?
Chris-how do they resize it?
ChrisBennet 07-19-2007 06:48 AM
They resize the case like you'd resize the big end of a connecting rod. Remove material from both case halves and then recut all the bores to standard size.
-Chris
tom1394racing 07-19-2007 08:26 AM
Donnie
I have a 2.7 7R case for sale that has had the resize and time cert work done by Ollies.
PM me if you are interested.
engguy 07-19-2007 07:49 PM
Steve rennsport, What machine did they use to machine the parting surfaces? Fly cut /lap?
And how many machine shops can do work on Porsche engines? I'm trying to find out if setting up a small shop would be worth it. I'm near Seattle wa.
Thanks ahead of time.
Steve@Rennsport 07-19-2007 09:49 PM
They use a very large surface grinder to machine the case halves.
IMHO, VERY few machine shops do quality work on 911 motors although quite a number do this sort of work,...:) :)
We do everything in house except for this particular operation to control quality and production schedules.
