-   -   hot cam and CIS (http://forums.pelicanparts.com/911-engine-rebuilding-forum/357926-hot-cam-cis.html)
hmd 07-19-2007 05:38 AM
hot cam and CIS
In Wayne's book the dicsussion about high overlap cam with cis resulting from intake reversions and sensor plate fluttering causing inaccurate fueling.
I like to know if this is only at idle and low rpm or over the entire rev range. For a track car with no smog worries and idle worry could you do with a really high overlap cam with a CIS system?
Rusty Heap 07-19-2007 02:51 PM
See my post titled dyno chart and fluctuation of the air/fuel ratio........
could be my problem......?
