HPV ignition coil source
Good day,
I am using HPV1 ignition in my twin-plug application, and I suspect one of the coils has gone bad. I understand HPV uses a standard GM coil on its packs and I would like to know if anyone can confirm that and tell which application it is from. In other words, what do I have to ask the local FLAPS to get the right coil ? "1988 Chevy Suburban ignition coil" , for example ?
TIA
Old 07-27-2007, 08:35 AM
Super Moderator
cstreit's Avatar
I think GM is right, but I never took it any further in my research either. Let us know if you find out, otherwise I guess you're calling electromotive...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-30-2007, 06:35 AM
I went to the store and asked for a coil from a 1997 cavalier. What I got did fit. I understand those GM parts are all the same (i.e. if it looks the same, it is the same). Car runs.
Cheers
Old 07-30-2007, 01:04 PM
Super Moderator
cstreit's Avatar
Good information, thanks!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 07-31-2007, 06:25 AM
