-   -   Intake: wha happened (http://forums.pelicanparts.com/911-engine-rebuilding-forum/359544-intake-wha-happened.html)
OldTee 07-30-2007 04:47 AM
My right side intake runner flanges cracked on the inside for # 4 and 5 on a freshly o/h'd 87 engine. I know I torqued them to spec using new intermediate flanges and gaskets. Is this common? Anyway, I need a replacement.
mb911 07-30-2007 06:20 AM
odd.. are you just going to have it welded?
OldTee 07-30-2007 06:31 AM
Hope to find a replacement part from somebody who moved up to carbs, or maybe a salvage engine, but if I can't find one at a reasonable price, welding is a possibility.
hcoles 07-30-2007 09:29 PM
curious why they cracked..
could be interesting to lay down some straight edges on the runner faces and along the heads..
just my 2 cents... so we can all be looking out for something you might find..
OldTee 07-31-2007 06:08 AM
I am gonna pull the engine next week. Will take some pics and post whatever I find.
OldTee 08-12-2007 09:21 AM
Found the problem. pic one problem: Pic 2 result and culprit.
http://forums.pelicanparts.com/uploa...1186935527.jpghttp://forums.pelicanparts.com/uploa...1186935548.jpg
I feel dumb but I used a little starting fluid just to aid things along. Result, a $500 purchase from Parts Heaven. :(
Facey 08-12-2007 10:32 AM
edit: me idiot....
so it was not seated well and when tightened down it developed a crack?
cstreit 08-12-2007 06:47 PM
I was going to suggest either an errant washer already on the stud... Obviously you would have seen that.
The shroud is very tight around the flanges there and if the edge got caught under the flange, it could have caused this when you tightened it down. Either way if you have it welded, make sure the sealing surface to the head is machined down flat and square again.
