OldTee's Avatar
Intake: wha happened
My right side intake runner flanges cracked on the inside for # 4 and 5 on a freshly o/h'd 87 engine. I know I torqued them to spec using new intermediate flanges and gaskets. Is this common? Anyway, I need a replacement.
Old Tee
all 911s sold
Old 07-30-2007, 04:47 AM
odd.. are you just going to have it welded?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 07-30-2007, 06:20 AM
OldTee's Avatar
Hope to find a replacement part from somebody who moved up to carbs, or maybe a salvage engine, but if I can't find one at a reasonable price, welding is a possibility.
Old Tee
all 911s sold
Old 07-30-2007, 06:31 AM
curious why they cracked..
could be interesting to lay down some straight edges on the runner faces and along the heads..
just my 2 cents... so we can all be looking out for something you might find..
Old 07-30-2007, 09:29 PM
OldTee's Avatar
I am gonna pull the engine next week. Will take some pics and post whatever I find.
Old Tee
all 911s sold
Old 07-31-2007, 06:08 AM
OldTee's Avatar
Found the problem. pic one problem: Pic 2 result and culprit.
I feel dumb but I used a little starting fluid just to aid things along. Result, a $500 purchase from Parts Heaven.
Old Tee
all 911s sold
Old 08-12-2007, 09:21 AM
user & abuser
edit: me idiot....
so it was not seated well and when tightened down it developed a crack?
vini vidi vici
Old 08-12-2007, 10:32 AM
Super Moderator
cstreit's Avatar
I was going to suggest either an errant washer already on the stud... Obviously you would have seen that.
The shroud is very tight around the flanges there and if the edge got caught under the flange, it could have caused this when you tightened it down. Either way if you have it welded, make sure the sealing surface to the head is machined down flat and square again.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-12-2007, 06:47 PM
