-   -   Case Savers questions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/359618-case-savers-questions.html)
HKZ Bob 07-30-2007 01:55 PM
Dear all,
if a case saver outer diameter 14mm x 2.0 will be installed in a 7R housing
isnīt there a risk that the cylinder gasket flange get to narrow.
These kind of case savers as listed at pelican requires a tapped prepared bore.
Is the process as followed.
Bore 12.1 mm and the use a three step tap and perform the M14 thread. But a M14 metric has a slope of 1.5. Why has the case saver a slope of 2.0
would be a 13mm be enough. That would leave 1,5 mm wall thickness.
Hope you can brighten my mind.
Bob
cgarr 07-31-2007 06:29 AM
It does get close to the edge by hand, if you use a mill you can cheat a little and give yourself a bit more room, I have 14mm taps from 1.0mm to 2.0 pitch, nothing really odd about that?
philippeF 07-31-2007 01:27 PM
hello
that's what i've done
i asked the same question a few monthes ago, worked fine
philippe
http://forums.pelicanparts.com/uploa...1185913530.jpg
the car
http://forums.pelicanparts.com/uploa...1185913595.jpg
HKZ Bob 07-31-2007 10:16 PM
Thank you Phillip.
Was the outside diameter M14 x 2.0 for the case savers.
And do you did the work.
Did they use an interference bore or tapped M14 and with loctide glued in the bold.
Bob
philippeF 08-01-2007 12:19 AM
hello
a machine shop did the job
they tappered to fit a M14x2 case saver. (first bored to diameter 12 and then tappered)
HKZ Bob 08-02-2007 10:17 AM
And did you never thought that the surface for the cylinder foot gasket gets to small.
The this copper ones.
Regards RW
philippeF 08-02-2007 02:17 PM
that's rather small, but that works
you may ask another people, i believe they'll tell you this is a "common" operation.
regards
Philippe
