HKZ Bob's Avatar
can I use EMPI 4011 Case Saver, 10mm ID X 1/2 " OD as well
Hello
I would like to know if I can use EMPI 4011 Case Saver, 10mm ID X 1/2 " OD
instead of the OD M14x2
I wonder why I canīt stay with 1/2" OD instead are going to M14.
I M14 pulls out. My case ist dead.
CASE SAVER INSERTS
Repair stripped and worn head stud threads. Case savers provide greater hold. Each kit has 8 inserts.
EMPI 4011 Case Saver, 10mm ID X 1/2 " OD, Set of 8 [/B]
Bob
Old 08-26-2007, 10:49 AM
911quest's Avatar
Just my .02 cents empi of today isn't the same as the good old day's I wouldn't use there products on a VW motor I definitely wouldn't use them a 911 engine.....
Tony Proasi
1969S
1957 VW Pickup
Old 08-26-2007, 12:22 PM
abit off center
cgarr's Avatar
I bet the 1/2" is a fine thread and thats what you don't want..
______________________
Craig
G2Performance
Old 08-26-2007, 01:58 PM
