Jeff Alton's Avatar
I am just sourcing a connector for the TPS on the Hargett throttles and then need to redo a couple of fuel lines (rails are in a different spot). Then hook up the linkages and go. My one reservation right now, but remember still not tested, is that the balance on each bank is not adjstable. The two banks can be balanced via the cables but there is no adjustment between each throttle on a given bank.
Cheers
www.turn3autosport.com
Old 02-13-2008, 02:40 PM
Steve W's Avatar
Hey Jeff, my congrats! You rwhp Dynojet numbers show you are making fantastic power. Your numbers work out to ~337 hp at the engine. Do you realize your numbers are very close to what a new 997S dynos, and they are no where at 2200 lbs. A 997S measures at around 300-308 hp at 6900 rpm at the wheels on a Dynojet, Cayman S comes in at 270-275. If you retrieved your Dynojet run files from your shop, you can open and view them with the Dynojet viewer from here, and take a screenshot and post it if you wish. http://www.dynojet.com/downloads/software.aspx
If you want to email the runs to me, I can make the screenshots for you also, and send them back to you. I can also overlay dyno runs of any variant of a Porsche motor if you wish, from other 3.4s, all the way to a 997GT3.
Old 02-13-2008, 05:59 PM
efhughes3's Avatar
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-14-2008, 04:56 PM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Subscribed... wow! Just finished going over the three threads... Outstanding work.
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 02-21-2008, 10:25 AM
9elf's Avatar
Hello Jeff. Great story unfolding with your build.
Is this the one that you bought? I would like a stand alone meter and this looks great. Not too bulky.
Thank you.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 02-21-2008, 02:21 PM
Jeff Alton's Avatar
Nope,
I bought 2 LC-1 controllers and then got one of these to go with it.
And I have a toggle switch to switch between the left bank and the right bank.
Cheers
Old 02-21-2008, 05:17 PM
