gumba's Avatar
correct plugs for 3.2 w/Electromotive
What spark plugs should I be using for a 3.2 w/Electromotive HPV-1 & 46mm Webers.
thanks.
'68 crewcab w/3.2 (46mm Webers, HPV-1, SSI's & sport muffler) & 5 sp.
Old 08-20-2007, 10:59 AM
Super Moderator
cstreit's Avatar
I'm partial to the NGK V-power plugs myself. You'll want to be careful that the electrode depth matches your current plugs.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-20-2007, 12:59 PM
gumba's Avatar
What heat range?
Old 08-21-2007, 03:56 PM
NGK - BPR7ES - the R designates a resistor. Go the 7 heat range.
Paul
Old 08-21-2007, 04:56 PM
Super Moderator
cstreit's Avatar
I use the 8 heat range to be safe, but if you're not in a high-compression low octane situation where detonation is possible, 7 is better... 9 was way too cold, fouled all the time.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 08-21-2007, 09:38 PM
Gumba,
If you experience plug fouling, you could try hotter plugs. I run NGK 6's on the track and around town with Electromotive XDI and 50 mm PMO's on a 3.6. Plug readings look really good!
Another reference is PMO's suggestion: Around town and normal driving NGK BP5ES up to 9:1 CR, and BP6ES for higher compression engines. Leave the gaps as they come (.028).
Take plug readings to be safe.
Lyn
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 09-07-2007, 06:28 PM
